I have had some odd issues with walls in 2012.
It seems like they are more 'attractive' to each other than they were in 2011. specifically any time the touch in parallel, they try to join up. And when you then move them they drag the adjoining walls along. I know this may be a feature, but it seems they are stickier than in 2011 and there are some problems.
See attached file. I just have a standard wall and a little base wall piece. They just cannot seem to be next to each other in parallel without messing each other up, once you start trying to edit or move things around.
I've attached a file with a few setups that are misbehaving. Hopefully the situation is clear, and the behavior replicates, if you try it.
