Thread: Revit 2012 - Masked region editing options disappear
    I could stop if I wanted to Mike Hardy-Brown's Avatar
    Melbourne, Australia
    282
    Question Revit 2012 - Masked region editing options disappear
    I am not sure if anyone else had had the same thing happen.
    In random situations the contextual tab for masked regions disappears
    (Much like the "Group" contextual tab used to disappear in RVT 2010 before bug fixes)
    This has happened on 2 machines at totally random times.
    In some cases, synching with the central file solves the situation, in other cases only an exit and restart will fix it.
    I have tried adding keyboard shortcuts (to trick RVT into thinking it can still complete the operation) but that does not work either.
    282
    Default Re: Revit 2012 - Masked region editing options disappear
    Same thing yesterday, only happened on 1 machine (twice) during the day
    This is the image showing no contextual/modify tab while in editing mode.
    also, I have copied the command from the journal file. which all looks normal except for <<Begin update dbar>>: not sure what that is?
    Jrn.MouseMove 0 , 1146 , 243
    'E 27-Apr-2011 16:00:50.994; 0:<
    Jrn.Command "Internal" , "Create a masking region , ID_MASKING_REGION"
    ' 0.742804 2:<<;PERF;MISC;regenerating
    'H 27-Apr-2011 16:00:51.829; 1:<
    Jrn.Data "Transaction Successful" _
    , "Masking Region"
    'C 27-Apr-2011 16:00:51.999; 0:< idle0_doc
    ' 0:< <<Begin update dbar>>
    2008-05
    Brunei
    299
    I also encounter this problem. But with the wall. The "Edit Profile" icon gone missing after selecting a wall.
    I just close and restart the program. And its back again.
    282
    Did you notice anything different in the Journal file ?
    2008-05
    Brunei
    299
    Quote Originally Posted by Mike Hardy-Brown View Post
    Sorry, I didnt get to check that file when it happened last monday. So far, it only happened once.
  1. 2015: irregular shaped crop region makes modeled objects disappear
    By FOUTJM in forum Revit - Platform
    Last Post: 2022-12-01, 08:23 PM
  2. 2010: My Ribbon disappear after editing Family
    By Pierre-Nelson NAVARRA in forum Revit - API
    Last Post: 2011-10-10, 03:09 PM
  3. Revit 2012 "Graphic Display Options" in the properties pallete
    By Joshua Kohl in forum Revit Architecture - General
    Last Post: 2011-05-06, 07:19 PM
  4. Masked Region
    By harkeychad in forum Revit Architecture - General
    Last Post: 2008-10-29, 09:00 PM
Tags for this Thread
