Thread: derived mirrored sheet metal part flat pattern
    2015-12
    2
    Red face derived mirrored sheet metal part flat pattern
    Hey All,
    I have a derived/mirrored sheet metal part that I would like to create a flat pattern for. I can get Inventor to create what it calls a flat pattern for this part, but the part is still bent. I have already tried creating a flat pattern in the original part before deriving the mirrored part. Any suggestions?
    NC
    2008-07
    Default Re: derived mirrored sheet metal part flat pattern
    Good Morning
    The first thing to do is check the sheet metal parameters within your derived part. When you mirror or derive a sheet metal component the material thickness is automatically set to default.
    Hope this helps
    2015-12
    293
    You can also try selecting a face prior to executing the Flat Pattern command.
  1. 2015: Inventor 2015 - Sheet Metal -Create Flat Pattern from sweep along path
    By arminm1988414598 in forum Inventor - General
    Last Post: 2014-07-28, 09:11 AM
  2. Copy & utilize sheet metal rules on Derived & Mirrored sheet metal parts
    Last Post: 2012-10-18, 12:40 PM
  3. Create Flat Pattern DXF from Sheet Metal on Check in
    Last Post: 2009-09-21, 09:43 PM
  4. Mirrored Sheet Metal Features Not in Flat Pattern?
    By Mike Y in forum Inventor - General
    Last Post: 2007-01-07, 07:48 PM
  5. Mirror a Sheet Metal Part That is Not a Derived part
    Last Post: 2006-05-14, 07:50 PM
