Thread: HOW TO POPULATE BLOCK ATTRIBUTE (TEXT) FROM TITLE SHEET DATA
    2011-04
    Default HOW TO POPULATE BLOCK ATTRIBUTE (TEXT) FROM TITLE SHEET DATA
    I need to create additional layout tabs with a title sheet inserted in each. The title sheet includes text attributes describing values A, B, C etc; In addition, I need to insert several different text blocks into each new layout that include the text value attributed to A,B,C for that layout. These values remain constant within each layout but differ to other layouts.
    So I'm hoping to type the individual values for A,B,C etc, only once per layout.
    Any thoughts on how this could be simplified?
    Default Re: HOW TO POPULATE BLOCK ATTRIBUTE (TEXT) FROM TITLE SHEET DATA
    Here is a video which I think shows what you need http://www.intelika.hr/blog/87-sastavnica-dinamiki-blok. If this is what interests you email me and I'll explain how to do that.
    Hrvoje Katić
    CAD manager
    hrvoje.katic@intelika.hr
    www.intelika.hr
    Moderator BlackBox's Avatar
    2009-11
    2,391
    (Not sure what version you're using?)
    Have you considered using Custom Properties with Sheet Set Manager (SSM) and simply populating said attributes with a Field which references the respective Custom Property(s)?
    "Potential has a shelf life." - Margaret Atwood
    Dynamic Blockhead Mod Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    i'll move this non-dynamic block question to the appropriate forum.
    S&D DB Sharing Forum
  1. Extract Title Block Attribute Data to Excel
    By bzrqmy in forum AutoCAD Customization
    Last Post: 2008-12-03, 07:57 AM
  2. Replies: 7
    Last Post: 2008-05-07, 09:59 PM
  3. Populate Attirbute Block data from Excel
    By avn in forum AutoCAD General
    Last Post: 2006-07-07, 04:56 PM
  4. Creating An Attribute Block For Revision or Title Block
    By fnguyen05 in forum AutoCAD General
    Last Post: 2005-12-22, 02:14 PM
  5. Help! Automatically grabbing 'Title Attribute' data
    By Gavin.Ostlund in forum VBA/COM Interop
    Last Post: 2004-10-21, 07:32 PM
Tags for this Thread
