I am trying to create a window array family using a nested single window family that is fully parametric (the window itself works perfectly in projects). The problem is that the parametric array works (array count, array distance to last, always centered on the family center reference plane) in the family, but as soon as I try to use it in a project, the windows become misaligned. When two windows are specified, one is in the proper location, and one is offset toward the exterior side of the wall by several inches. When three windows are specified in the array count, the same thing happens with the first two windows, and the third is rotated 90 degrees! It was created using a linear array, so I don't know why this is happening. As a test, I also used a linear array with no changeable parameters and the same thing happened, so it seems to be a function of the array itself and not the parameters I am specifying. I have attached the file if you would like to look at the family. Any help would be great!
Thanks
