Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Lists within lists - simplify
    2015-10
    Belgrade, Serbia, Europe
    564
    Default Lists within lists - simplify
    Is there any more efficant way to convert list of type :
    ((1 2 3) (2 3 4) ((5 7 3)) (((G))) ((((A)))))
    to list
    (1 2 3 2 3 4 5 7 3 G A)
    I've managed to do this only to this level
    ((1 2 3) (2 3 4) ((5 7 3)))
    but I want for all levels of brackets...
    Here is my code :
    (defun lstnlst1 (lst / lstn)
    (foreach el lst
    (if (= (listp el) nil)
    (setq lstn (cons el lstn))
    (progn
    (foreach ee el
    (if (= (listp ee) nil)
    (setq lstn (cons ee lstn))
    (progn
    (foreach e ee
    (if (= (listp e) nil)
    (setq lstn (cons e lstn))
    (setq lstn (reverse lstn))
    M.R.
    2010-10
    535
    Default Re: Lists within lists - simplify
    try this
    (defun SimplifyList (lst / looplst a b c y newlst )
    (defun looplst (l)
          	(if (listp (setq y (car l)))
          		(looplst  y) l)
          (while (setq a (car lst))
                 (setq b (cdr lst))
                 (setq c (looplst a))
                	(foreach x c
                          	(setq newlst (cons x newlst)))
                (setq lst b)
          (reverse newlst)
    (setq yourlist '((1 2 3) (2 3 4) ((5 7 3)) (((G))) ((((A))))))
    (simplifylist yourlist)
    2015-10
    564
    You didn't understand question... I want simplification of all possible combinations of lists with many sublists with many brackets...
    Command: (setq lst '(((( 1 3 6) (((((6 9 4))))) ))) )
    ((((1 3 6) (((((6 9 4))))))))
    Command: (simplifylist lst)
    (1 3 6)
    As you can see I get only first part of this new list type...
    Any ideas...
    M.R.
    2010-10
    535
    Funny how you post a example of your list then give another format afterwards
    But it does work on the first list condition right?
    Now, a long time ago i;'ve was playing around with recursion for nested list such as yours, I noticed that
    there are too many variations,
    So i came up with just one routine no matter how nested the list is
    (defun ConvertList  (lst)
          (read (strcat "("
                        (vl-list->string
                              (vl-remove-if
                                    '(lambda (x)
                                           (or
                                                 (= x 40)
                                                 (= x 41)))
                                    (vl-string->list
                                          (vl-princ-to-string lst))))
    Hope this one helps,
    2015-10
    564
    That's it, you did it...
    Thanks, pbejse
    (nice idea to convert list to string and then remove all brackets with vl-remove-if and lambda)
    This is real programming solution, I would give you an accolade if I could...
    Thanks again...
    2010-10
    535
    Glad it works for you M.R.
    Cheers
    2003-11
    Dublin, Ireland.
    152
    Brilliant.
    2008-02
    1,141
    (defun AT:ListCondense (lst)
      ;; Condense list of sublists to a single list
      ;; lst - list of lists to process
      ;; Alan J. Thompson, 08.10.10
      (if lst
        (if (listp lst)
          (append (AT:ListCondense (car lst)) (AT:ListCondense (cdr lst)))
          (list lst)
    2003-11
    Dublin, Ireland.
    152
    NIce one Alan.
    Are you using the function within itself here???
    If you have the time, could you explain what you are doing?
    Cheers
    2008-02
    1,141
    Quote Originally Posted by jmcshane View Post
    NIce one Alan.
    Cheers
    Yes, it's recursive.
    When I get a chance, I'll talk you through it.
  1. Drawing Lists
    By timsea81 in forum Revit MEP - General
    Last Post: 2010-01-07, 10:01 PM
  2. Drawing Lists
    By david.delcher in forum Revit Architecture - General
    Last Post: 2006-10-24, 04:54 PM
