Thread: 3D sketch failure - how to figure out where the failure is??
    2011-04
    12
    Default 3D sketch failure - how to figure out where the failure is??
    I have a 3d Sketch controlling a frame generator assembly. I needed to change a 2D sketch that was controlling the 3d sketch via "Include geometry"
    However, When I changed the 2D sketch the entire 3D sketch turned pink and the sketch said there were errors in the constraints. Problem is I cannot find where the problem is...
    I have narrowed it down to the lines circled in the screenshot (because when I delete them the problem goes away). But I have a lot depending on the frame members designated by those lines - So I dont want to delete them. I think the problem is in the reference at the point where the lines meet - but when I try to delete that reference it throws an error.
    Frustrating!!
    Any suggestions? Screenshot and .ipt are attached.
    2011-04
    12
    Default Re: 3D sketch failure - how to figure out where the failure is??
    The error returned when I try to "Break Link" Between the bottom projected points is as follows:
    Problems occurred while solving sketch. Use Edit Sketch to change sketch geometry or constraints.
    Sketch has constraints that could not be solved. Try deleting some constraints.
    I cannot hit "Accept." "Cancel" Is the only option.
  1. PDF Underlay Failure
    By gblack.127549 in forum AutoCAD General
    Last Post: 2009-06-29, 05:54 PM
  2. Is Vista a failure?
    By michael.12445 in forum Windows Vista
    Last Post: 2008-11-12, 05:16 PM
  3. Failure to Upgrade to 9.1
    By efeiss in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2006-11-11, 12:16 AM
  4. dimensioning failure
    By alli_lung in forum ACA General
    Last Post: 2005-06-07, 03:48 PM
