Thread: make a surface into a 3d solid
    2009-07
    Default make a surface into a 3d solid
    Does anyone know if civil 3d has a way to convert a tin surface to a 3d solid object?
    Ultimately I want to be able to make an stl file from a surface that was created using contours, 3d faces or points. If civ3d is unable to do this are there any other apps or LSP's that might work?
    I've already tried F2S (face to solid), convtosolid, convertto3dsolids and a few combinations of exploding, unioning and convtosolid with extrusions.
    any help or ideas would be greatly appreciated.
    Civil Engineering Moderator civil3Dguide's Avatar
    2006-01
    Temecula, CA
    281
    Default Re: make a surface into a 3d solid
    I spent a little bit of time on this once myself with little success. It was a very large surface that I was working with and in the end I didn't see the point, because this guy was trying to convert it to use in some custom program.
  1. 2006: how to make twisted solid cube in autocad?
    By sanjay9172385130 in forum AutoCAD 3D (2006 or below)
    Last Post: 2012-08-22, 09:57 PM
  2. Surface from solid
    By jimmy_goodall in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2010-09-21, 01:19 PM
  3. Revit Stairs - How to make solid balusters?
    By samov in forum Revit Architecture - General
    Last Post: 2010-01-05, 04:24 PM
  4. 3D regions join to make solid
    By ericheatherh in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-02-17, 10:12 AM
  5. AutoCAD 2008 - Make a hole in a Solid
    By kwong in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-05-15, 11:59 AM
