Thread: Stairs again
    2011-02
    4
    Default Stairs again
    Hi, I have problems with stairs. I'm trying to create custom stairs but some problems occurred:
    1. Wrong up direction, and when I'm trying to change it I get error.
    2. Stairs are shown above level section.
    2004-06
    Memphis TN area
    7,048
    Default Re: Stairs again
    How are you starting the sketch? I just tried it by sketching the stairs as a straight run first, then deleting the stringer boundary lines, and sketching new boundary lines and riser lines and connecting them all together. It went the wrong way when I first finished the sketch, but then I clicked on the little arrow in plan view to reverse the run.
    The only problem was my stringers on each side were flat instead of following the slope of the stairs. But you could easily get around that by using a railing profile and drawing a "railing" along each side of the stairs that would serve as a stringer. Or me personally, I would just not show stringers at all.
    2011-02
    4
    Oh, i found out the problem, view in this level was to low, i had to lift it up (:
  1. Replies: 5
    Last Post: 2010-07-28, 06:53 PM
  2. I need help in stairs
    By avalencia60 in forum Revit Architecture - General
    Last Post: 2010-03-10, 04:45 PM
  3. Stairs and Plan Regions or Why do I see stairs when I shouldn't!?
    By credel in forum Revit Architecture - General
    Last Post: 2008-05-29, 05:14 PM
  4. Multi Level Stairs - Self intersecting stairs
    By Andre Baros in forum Revit - Known Issues & Work-Arounds (Read only)
    Last Post: 2006-05-11, 09:42 AM
  5. Multi Level Stairs - Self intersecting stairs
    By Andre Baros in forum Revit Architecture - Tips & Tricks
    Last Post: 2006-05-11, 08:06 AM
