Don't be sorry for venting! It's always good to get that stuff off ones chest. This is a good place to do just that!Originally Posted by jblock
Keep in mind that all AEC objects can be generated from standard acad linework. Walls, column grids, etc. can all be created from standard linework. Simply right click a tool such as a wall on a palette & choose "Apply tool properties to..., Linework".
Also, alot of the commands for modifying objects are built around the premise that the building design will change as you go through the project cycle. Using grips to modify objects, smart nodes & other things will speed up modification for when things do change. Attaching Structural Coloumns to Column grids will allow you to modify the grid & the columns will change with it.
There are lots of tips that take a while to arm your toolbelt with. Give yourself time. What you are doing is huge! Trying to learn this massive program at the same time as producing an entire project is not what I would recommend by any means, but since it is what you are stuck with, we will try to help you as best as we can.
I hate to ask this, but would you mind defining what you refer to as drawing "schematically"?
