Results 1 to 10 of 10
Thread: anyone tried Data Link to an Excel file in 2012?
    2008-05
    Boston
    65
    Default anyone tried Data Link to an Excel file in 2012?
    Has anyone tried Data Link to an Excel file in 2012?
    Notice any improvements in performance or anything else related to this feature? Thank you.
    2004-08
    Hartford, Michigan
    3,086
    Default Re: anyone tried Data Link to an Excel file in 2012?
    I have data linked our quantity table in, dont know that I noticed much of a difference, just recently started using the feature (only the past 3 projects) so I dont have enough experience with it to be able to notice the differences.
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    2008-05
    Boston
    65
    Ok thanks for the response.
    We use it quite a bit in 2010 for spreadsheets, some of which can be quite long.
    Performance is often slow when they get beyond a few hundred rows of data. Not sure if there were any incremental improvements in 2012 that'd help.
    Active Member dherbstr's Avatar
    2008-07
    Washington DC
    78
    I use it for door/window/finish schedules, but haven't noticed much of a difference. Those are <100 items anyway, but our sheet layouts with all the datalinks and tables runs slower than other drawings.
    CAD Lead
    US Inspect, LLC
    Washington DC
    I've used Data Link a lot. It's not bad, but I've found something that works better. Try XL2CAD. It works just as well as Data Link, but the plotting hard copy quality is much better.
    2006-05
    5
    Is XL2CAd a command, a lisp routine, a diesle expression, or a program? If not a command, where does one find this XL2CAD? Who developed it? How does it work?
    South Eastern US, exact location unknown
    1,369
    Info here on it.
    J. Murphy
    AKA
    Murph
    The former AutoCAD MAP3D Power User
    100 Club Lemons's Avatar
    2001-06
    Beautiful Charleston, South Carolina
    149
    Quote Originally Posted by Jmurphy View Post
    Info here on it.
    Ooooh, this looks fantastic!!! I can finally givve up my old ways.
    Thank you, thank you, thank you!
    Drop me off in Asheville.
    I could stop if I wanted to Liamnacuac's Avatar
    2005-12
    Earth
    441
    XL2CAD still runs on VBA. I have had problems with it, if anyone is an XL2CAD pro, I have questions..
    That was an older version. When we saw the impact that VBA had on 64bit, we began porting all our applications to the Managed .NET interface. We no longer sell any VBA based tools.
  1. excel data link
    By miguelcid in forum AutoLISP
    Last Post: 2010-10-27, 03:30 PM
  2. Excel Data Link Path Problem
    By aesmoak in forum AutoCAD General
    Last Post: 2008-09-23, 09:57 PM
  3. inserting excel via data link into table
    By rjairath in forum AutoCAD General
    Last Post: 2007-12-19, 04:47 PM
  4. Program to Link Square Footage Data to Excel
    By julie_starzynski in forum AutoCAD General
    Last Post: 2006-11-30, 03:47 PM
  5. Insert data from an Excel file
    By cadd4la in forum VBA/COM Interop
    Last Post: 2006-03-27, 01:35 AM
