Thread: AutoCAD - 2012 - Heidi Driver Crash
    All AUGI, all the time gfreddog's Avatar
    2003-07
    Pequannock NJ US of A
    641
    Default AutoCAD - 2012 - Heidi Driver Crash
    Ok so I'm running AutoCAD 2012 (Vanilla) on:
    Machine Configuration
    Dell Optiplex 980
    Intel Core i7 CPU
    Processor Speed : 2.8 GHz
    RAM 4G
    32 Bit System
    Windows 7 Opsys
    Video Card:
    Name : ATI Radeon HD 3400 Series
    Manufacturer : ATI
    Chip set : Radeon HD 3400 Series
    Memory : 1749 MB
    Driver : 8.17.0010.1070
    Usually 2 to 3 times a week the driver crashes stating:
    "The configured Heidi Driver cannot be loaded.".
    Any ideas?
    George V. Fournier Jr., CTS
    Sr. Sales Engineer - Autodesk Product Design Suite Premium 2014
    2006 AUGI DAWG (7th) - NJ AUGI Camp
    Volunteer Firefighter since 1985 & Bagpiper Wanna-be
    With the freedom of expression comes great responsibility
    2003-07
    641
    Default Re: AutoCAD - 2012 - Heidi Driver Crash
    The Autodesk forums have some people with the same issue but no solutions.
    Member bellis.239472's Avatar
    2010-01
    25
    Yes I have the same issue. Very annoying!
    2003-07
    641
    No luck yet just boiler plate responses from Autodesk:
    Thank you for choosing Autodesk Support.
    I understand that when launching AutoCAD 2012, it shows the error "Heidi Module Load Error. The configured Heidi driver cannot be loaded. Switching to default software driver."
    Heidi errors like this have to do with the video driver on your system. Often simply uninstalling and reinstalling the video driver will fix the problem. Aside from getting the current driver from the manufacturer's web site, you can also check your video card and driver against those that we have tested and certified:
    http://www.autodesk.com/autocad-graphicscard
    Sometimes the latest video driver available from the manufacturer is not the latest one that we have tested. For the reinstall process, I would recommend uninstalling your current video driver, reboot, install the driver again (or an updated version), and reboot once more.
    Another cause of the Heidi error could be your printer driver. Try changing the default printer driver on your system and then launch AutoCAD to see if the error occurs.
    If reinstalling the video driver or changing the default printer does not fix the problem and if you can get into AutoCAD and enter the 3DCONFIG command, hit the Manual Tune button in the window that comes up and then turn off Enable Hardware Acceleration. If you cannot get into AutoCAD, try turning off video hardware acceleration in the Windows display settings or add a /nohardware switch to the AutoCAD shortcut. Here is an article about using the /nohardware switch:
    http://usa.autodesk.com/getdoc/id=TS1056259
    Please let me know if this resolves the issue.
    Best regards,
    Autodesk Support Team
    Oh joy
    Member miles9x's Avatar
    2006-01
    North Dakota
    17
    From Autodes Support:
    I understand that if the computer is locked, goes to sleep, or the screen saver becomes active, AutoCAD 2012 shows the message "The configured Heidi driver cannot be loaded. Switching to default software driver."
    This warning message is actually by design. I can make it happen on my system and I have a certified video card. When the computer sleeps or the screen saver turns on, the video mode changes. This can cause a problem for AutoCAD if it is running. The program switches things to prevent a crash.
    Try setting the desktop theme to Windows Basic. Not having Aero active may stop the message from occurring.
    Updating to the latest video driver or the latest driver that we have tested may also help. Here is our graphics hardware list:
    Installing DirectX may help too:
    http://www.microsoft.com/download/en/details.aspx?id=35
    Turning off hardware acceleration in 3DCONFIG inside AutoCAD may also prevent it from happening.
    I hope this helps. Please let me know if you have further questions.
    Best regards,
    Bryce Thelin
  1. Replies: 1
    Last Post: 2012-07-09, 04:47 PM
  2. Heidi Driver
    By tonyv in forum CAD Management - General
    Last Post: 2012-05-04, 12:28 PM
  3. Heidi driver fails to load
    By kleenhippie in forum AMEP General
    Last Post: 2010-07-14, 01:16 PM
  4. Looking for a Heidi driver for a HP DesignJet 500
    By jonathan_fairholm in forum AutoCAD Plotting
    Last Post: 2007-04-08, 05:05 AM
  5. Minolta majicolor 3100 printer - heidi driver
    By r.ancel in forum AutoCAD Plotting
    Last Post: 2004-09-12, 09:27 PM
Tags for this Thread
