I'm getting weird gaps in the Sanitary Tee fitting not sure why. Can anyone advise if this is a setting somewhere? Tried pipe connector tolerance to no avail. RMEP 2012 M_Tee Sanitary - PVC - Sch 40 - DWV
I opened both the imperial and metric template and cannot reproduce this issue.
Usually when there is a gap between the pipe and fitting it has to do with the connector.
The connector in the family is actually past the extents of the solid or symbolic line.You can really see when this is a problem when you un-check use annotation scale.
If you are using the OOTB fittings than I'm not sure what is causing this.
Does it do this using a default template or just in that particular project?
Looks like someone hosted a connector to an ref plane, and didnt lock the flex on the fitting to the same plane.
Thanks it seemed to be just that 1 fitting maybe it was edited went back to OOTB and now its fine. Cheers.
