Results 1 to 8 of 8
Thread: Detach Leader From Mtext
    2015-09
    420
    Default Detach Leader From Mtext
    Hello AUGI Members,
    When using the Qleader command leaders and Mtext are placed that are associated with each other....move the text and the leader will follow. Is there a way to detach the leader from the text at the time it is placed on the drawing....??
    Right now I am using the Express tools .qldetachset command after the leader and Mtext have been placed.
    Any suggestions or recommendations would be appreciated.
    Regards,
    Vinny
    in the upper right corner
    3,504
    Default Re: Detach Leader From Mtext
    I'm not aware of any setting to turn that off (maybe I just haven't heard of one).
    What I usually do is just copy the leader, erase the "associated" one and place the copied one in it's place... then copy the mtext and leader(s) over and over for what ever I need.
    5,714
    Try the qldetachset command.
    2015-09
    420
    RenderMan,
    Thank you for your response.....!
    I am already using the qldetachset command after the leader and Mtext string is placed on the drawing However, I am trying to perform the detach operation automatically without the user having to run the qldetachset command manually.
    Do you know of any other way to accomplish this....?? basically I want the ability to dis-associate the leaders from the Mtext ....!
    Any assistance would be appreciated.
    Regards,
    Vince
    0,0,0 The Origin
    8,570
    Could you use the old leader command instead?
    DIM
    LEA
    Has to be from the command line, though.
    2008-02
    12
    ok I am confused. Why are you detaching the leader from the text? Also, we dont use "qleader" since AutoCAD came out with Multileaders. You might try using that to get the desired results.
    3,504
    Quote Originally Posted by knelson.160344 View Post
    I can't speak for others but I don't like having the leaders attached, it causes me all kinds of headaches and there's never been a benefit to me to have them associated, I've tried.
    For one thing, it doesn't allow you to manipulate the distance from the text to the first bend, which I do allot. With associated leaders, you are given that distance and you are only left with end of the leader to manipulate. If you have a tricky place to sneak in a leader and still want to line up your text and make it look nice, you may need to stretch the distance from the text to the bend in the leader.
    Of course that is my opinion, it's worked great for 15+ years.
    Maybe some day I will look into multi leaders when I'm forced to .
    3,504
    Ok I came across this post from 2011 (someone gave me some reps, thanks), and now I'm taking my words back. I use Multileaders all the time now.
    I moved to a company in 2016 that uses them exclusively, and all the styles needed in the company templates.
    Im not sure what my problem was before, but you CAN manipulate the landing length which seemed to be one of my issues.
    I've not had much of a problem fitting mleaders/mtext where I need it even in tricky places.
    What drives me nuts are people who use hard returns in the text so you can't easily manipulate it after.
    It's ok on occasion to do a hard return if it serves a purpose, but to simply hit return to fit it in a place (vs stretching the text box) hurts my feelings.
  1. Mtext on leader not automatic?
    By JohnnyCicc in forum AutoCAD General
    Last Post: 2011-06-09, 07:19 PM
  2. Mtext Prefix in Leader
    By BeKirra in forum AutoLISP
    Last Post: 2010-02-09, 09:25 PM
  3. Leader & Mtext
    By dcs in forum AutoCAD General
    Last Post: 2007-10-22, 12:34 PM
  4. Mtext and Leader Issues
    By jabtay in forum AutoCAD General
    Last Post: 2007-08-21, 12:03 PM
  5. Quick Leader & mtext
    By jkramer in forum ACA General
    Last Post: 2007-01-11, 08:16 PM
