Thread: Model Feature Lines Disappeared
    2015-12
    36
    Default Model Feature Lines Disappeared
    I have been working on a model for a grading plan for a couple of days and had created ~35 feature lines as break lines in the model.
    I was editing the model to optimize and balance the grading.
    Something happened and now nearly all of my model feature lines are gone. Only 4-5 are left and they are still all on C-TOPO-Feat layer. So it could not have been an accidental deletion, otherwise they would all be gone.
    I ran recover, it fixed 32 errors but the feature lines are still gone.
    Any suggestions to what happened?
    Any suggestions how to fix/recover the lines? .bak won't work because I had saved the file recently without knowing there was a problem.....
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: Model Feature Lines Disappeared
    What version of C3D?
    This was a common problem in C3D 2008-2009. I might have also seen people complaining about it in C3D 2010, but I can't remember for sure. I don't think I've seen anyone complain about this issue in C3D 2011-2012 yet, so hopefully it's been fixed.
    I don't recall ever seeing a fix for this problem. A lot of people got in the habit of exploding gradings as soon as they were set, to avoid this problem. Exploding the grading destroys the dynamic nature of the model, but it seemed to keep things from disappearing.
    2015-12
    36
    We are running Civil 3D 2011 Version 2. Sounds like the problem may still be around.
    I can't think of anything I did to make them go away. Especially to leave five feature lines behind on the same level.
    Thank you for your response.
  1. Model Disappeared and i can find it....
    By mickaeL_renauD in forum 3ds Max - General
    Last Post: 2008-11-11, 06:29 PM
  2. Datum lines have disappeared
    By vandelay in forum Revit Architecture - General
    Last Post: 2008-03-11, 12:50 PM
  3. Feature lines not right.
    By Glenn Pope in forum AutoCAD Civil 3D - Corridors
    Last Post: 2006-07-21, 05:12 AM
  4. Area Boundary Lines Disappeared!!!
    By YCHEN in forum Revit Architecture - General
    Last Post: 2006-06-16, 05:11 PM
  5. Feature lines
    By cadpres in forum Civil 3D Wish List
    Last Post: 2006-01-04, 07:14 PM
