Thread: zoom object problem
    Active Member Neo_Richard_Blake's Avatar
    2006-09
    Bakersfield, CA
    67
    Default zoom object problem
    First off, I'm using AutoCAD LT 2012. That said, I have a problem with a particular drawing and the ZOOM, OBJECT command. I can zoom to windows, extents, etc. just fine, but when I go to ZOOM, and select OBJECT, then select my objects (or even if they're selected first) I don't get a closeup of the objects. Instead each object, has it's own arbitrary level of zoom, and it's not a rational zoom as far as I can tell. It doesn't even center on the items. Has anyone else seen this before? I can't figure out what's going on. And it's only on this one particular drawing. All the other drawings I've tried this zoom just fine to objects. Thanks for the help.
    Sean Thompson
    Drafter
    IES Engineering
    Bakersfield, CA
    100 Club pendean's Avatar
    2001-12
    Dallas, TX
    171
    Default Re: zoom object problem
    If it is as you note "only on this one particular drawing", as a test INSERT this file into a trouble-free empty template file of yours and see what it does and if that fixes it.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    2006-09
    Bakersfield, CA
    67
    Nope, it's crazy in the new drawing after insertion as well. I tried it by exploding the block, and also by not exploding and trying within Block Editor.
    Sean Thompson
    Drafter
    IES Engineering
    Bakersfield, CA
    2006-09
    Bakersfield, CA
    67
    Okay, so it ended up that the problem was one of size in distance. For some reason, objects' lower left "origin", so to speak, was hundreds of thousands of feet from true origin. I just selected all, cut it to the clipboard (Ctrl+X) and then pasted from the clipboard (Ctrl+V). After that, zooming to an object worked as it should. So, if anyone else has this problem, there's a possible solution.
    Sean Thompson
    Drafter
    IES Engineering
    Bakersfield, CA
  1. zoom & instant pan problem
    By gpapachrisanthakis841392 in forum AutoCAD General
    Last Post: 2011-07-25, 03:58 PM
  2. Zoom object within lisp
    By JSelf in forum AutoLISP
    Last Post: 2010-01-11, 08:24 AM
  3. Zoom problem + dimension & leader problem
    By Mamma Jamma in forum AutoCAD General
    Last Post: 2009-06-16, 07:21 PM
  4. Zoom all problem
    By Cheuk Ling in forum AutoCAD General
    Last Post: 2008-09-11, 12:05 PM
  5. Zoom all problem
    By thetlin24 in forum CAD Management - General
    Last Post: 2008-09-08, 01:28 PM
