I saw one a similar request like this way back. written by Peter of this forum called Bump.lsp
http://www.augi.com/forums/showthread.php?t=126841
Lee Mac
Do each of your values have the same attribute tag?, i.e. Do "0" and "1" both have attribute tag "Rev"? (similar for Description etc.)
If they do, a program would have to rely on the order of the attributes in the block definition and *hope* it turns out OK..
You're right Lee. a program like this will be block and position/order specific. in which case Tag Name is irrelevant
One thing i dont get is the way you "bump" the Rev box. I would have think it would be like B would take place where A was and C -> B 0->C 1->0 and leave the top one as blank forthe As built info
(defun c:test (/ TB AttColl cnt)
(setq TB (vlax-ename->vla-object (car (entsel))))
(setq AttColl (vlax-invoke TB 'GetAttributes) cnt 6)
(repeat (- (length AttColl) 7)
(setq TheText (vla-get-textstring (nth (setq cnt (1+ cnt)) AttColl)))
(vla-put-textstring (nth (- cnt 7) AttColl) TheText
(repeat 7
(vla-put-textstring (nth cnt AttColl) ""
)(setq cnt (1- cnt))
In this example. (see attached) I already know that the second line of this revision box starts with attribute number 7 (rev_1)
(actually 6 of the list <index 0>). I can tell the code to start reading and pass it on the (rev_0)
and leave the last one as blank, or we can write it in such away the code will prompt you for the values on the last 7 tags
like this
(defun c:test2 (/ TB AttColl cnt)
(setq cnt 20)
(foreach prmpt '("Revision Number/Letter: "
"Description: "
"Date: "
"Drawn By: "
"Checked By"
"Approved By [1]: "
"Approved By [2]: ")
(while (eq ""
(setq New (getstring (strcat "\n" prmpt)))))
(vla-put-textstring (nth (setq cnt (1+ cnt)) AttColl) New)
