Thread: Lines in Contour Labels
    36
    Default Lines in Contour Labels
    When I label my contours at 1"=40 and text size 0.1 my contour labels look fine.
    When I change the scale to 1"=20' for a detailed view of an area, the contour label text is smaller (0.5) as it should be. However, I get these lines above and below the contour label that appear to be hidden behind the text mask at 1"=40' and show above and below the label at 1"=20'
    Any suggestions how to make these lines go away. They are stopping publication of our project.
    as
    2004-11
    20
    Default Re: Lines in Contour Labels
    click on the label. in the "Properties" dialog box, the 2nd line down is "Display Contour Label Line". Change this to "False". You can do a "Quick Select" to do multiple labels.
    36
    Thank you for the help. So many things to know....
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Note that you can change your command settings so that the contour line labels are set this way as they are created. That way you don't have to constantly change this setting as you label contours.
    Toolspace -> Settings -> Surface -> Commands -> AddContourLabeling -> [rt-click] Edit Command Settings -> Contour Labeling Defaults -> Display Contour Label Line
  1. Contour Labels don't display without TIN lines displayed
    By BoarsNest01 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2013-02-27, 12:56 PM
  2. Contour Labels
    By Anthony Rhodes in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2012-01-26, 04:20 PM
  3. Lines in Contour Labels
    By aspencer.226869 in forum AutoCAD Civil 3D - General
    Last Post: 2011-06-06, 12:30 AM
  4. Contour Labels
    By Phillip_Miller in forum Revit Architecture - General
    Last Post: 2008-12-09, 01:22 AM
