Thread: Getting Area of Sloped Walls Created by Mass
    2011-06
    6
    Default Getting Area of Sloped Walls Created by Mass
    We are modelling a building with several sloped curtain walls for an estimating schematic. However, both in Vico Office or Revit's built-in schedules, we are unable to obtain the area of the sloped curtain walls. We have tried both a custom wall family as well as a curtain system. The other walls attached to the mass document correctly. We have also tried calculation by panel, using a custom panel in the sloped walls, but the panels are not all of uniform size so this does not work.
    Any help or ideas are appreciated!
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Default Re: Getting Area of Sloped Walls Created by Mass
    Try setting the Maximum Distance to None for the Grids--which will make it a single panel,
    then click it to get the area in properties.
    Or, you should be able to set up a Material Takeoff schedule and get the Material Area with Grand Total
    for all the glazed panels.
    cheers
    2011-06
    6
    Quote Originally Posted by cliff collins View Post
    cheers
    Thanks! That worked!
  1. created pattern based conceptual mass.... now what??
    By jongalbraith435747 in forum Revit - Conceptual Design Tools
    Last Post: 2012-03-11, 12:16 AM
  2. Ability to detach objects from Mass, which were created from faces of Mass objects
    Last Post: 2009-09-20, 07:04 PM
  3. Sloped Inserts in sloped walls
    By lukec in forum Revit Architecture - General
    Last Post: 2008-08-08, 06:31 PM
  4. A Mass created in Project can be save as Family ?
    By ljupadhyay in forum Revit Architecture - Families
    Last Post: 2007-07-16, 07:17 PM
  5. curtain wall created using mass
    By natete in forum Revit Architecture - General
    Last Post: 2007-06-01, 06:07 PM
Tags for this Thread
