Hi folks, this is my first post here on the forums. I'm hoping someone out there has come across this problem before!
I have some nurbs curves created in Rhino and exported to dwg then linked into my Revit project.
The curves represent CHS chords of a truss in a bridge and they bend in elevation & plan. I have concluded that I can't model these with structural framing so went for the conceptual mass approach. Having created in place mass families using 3d spline to snap to nodes along the curve, it was possible to then use the edge of the mass to create a sweep with a tube profile.
The problem is this only approximates the nurbs curve, and also is time consuming. Also have trouble representing the chords in coarse view so they represent as single lines not double.
It seems Revit 3d tools are not well equipped to deal with this sort of geometry. Does anyone have any experience or workflows that may help?
3d view of part of the bridge attached for info
Cheers
