Thread: Revit and CAD standard
    2008-10
    65
    Default Revit and CAD standard
    Dear All,
    We are in the transition phase ( from AutoCAD to Revit). 50% of office is on Revit. 50% on AutoCAD. so we need to export Revit views to AutoCAD for these users which create a drawing with its own CAD standard.
    Being CAD Manager, what approch is correct. ( should I change Revit standard to match AutoCAD standard or Vice versa.
    Which is the best way to make both user happy.
    Regards,
    Annie
    2004-06
    Memphis TN area
    6,701
    Default Re: Revit and CAD standard
    Well I can tell you for a fact that there simply is no way to make EVERYTHING in Revit match EVERYTHING in AutoCAD. Vice versa may be possible but I can't say for sure.
    In my opinion this is why projects should be documented 100% in Revit. Trying to mix and match Revit and CAD will prove quite difficult to get everything to match up just right.
    AERC, PLLC
    Hernando, Mississippi
  1. Revit Standard Library Management
    By ming87 in forum Revit Architecture - General
    Last Post: 2012-04-13, 08:20 PM
  2. Standard revit parameters, families etc...
    By picasac in forum Revit - Platform
    Last Post: 2012-01-31, 09:20 PM
  3. AEC (UK) BIM Standard for Revit
    By gdury in forum Revit MEP - United Kingdom
    Last Post: 2011-11-09, 01:28 PM
  4. What does Revit have over standard Autocad?
    By framedNlv in forum Revit MEP - General
    Last Post: 2009-05-15, 01:28 AM
  5. Revit Standard Keynotes
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2006-12-13, 12:15 AM
