You could probably achieve a decent performance increase by reducing the number of times you call hide / unhide / setVisibility. Specifically, the first part of the code where it hides and then unhides elements by category seems redundant.
I've used code similar to the following to do this sort of thing.
// Get the selected elements
var selectedElements = myDocument.Selection.Elements.Cast<Element>().ToArray();
// Use a collector for this particular view
using (FilteredElementCollector collector = new FilteredElementCollector(myDocument, myView.Id))
// Get all elements in the view excluding the selected elements
var elementsToHide = collector
.WhereElementIsNotElementType()
.Excluding(selectedElements.Select(e => e.Id).ToArray())
.ToElements();
// Populate an ElementSet with the elements to be hidden
using (var elementSet = new ElementSet())
foreach (var element in elementsToHide)
if (element.CanBeHidden(myView) && !element.IsHidden(myView))
elementSet.Insert(element);
// Hide the elements
myView.Hide(elementSet);
Note that you may need to consider relationships between elements. For example, in my case I was trying to isolate a hosted element and the hosted element was automatically hidden with it's host. In this case I excluded the host from the ElementSet being hidden, and then called myView.setVisibility(hostElement.Category, false) to hide the host without hiding it's hosted elements.
