I need help when i try to view my corridor sections the grid is huge it shows negative elevations and all my 2d plan linework as well as my 2d surface and all the sections in a corridor 2d model.....
Are you viewing through the corridor/section editor or through created section views?
Basically, a section view will assign the top and bottom elevations based on what elevations it finds in the sources you have sampled. If you have a source with elevations of zero, then it will drop the bottom to below zero to dislay it.
I would start by removing all of your sources, and adding them one by one to see if you can tell if one source in particular has something that forces it down. Once you know that, then you can search that source to find your error. You might want to make sure that your corridor uses a good profile, because if no profile exists where you put your section, it will insert your assembly at zero.
Hope I have something to help you start.
