Hello,
I've been having this problem: Some of the elements that I try to paste onto Level 2 are showing up on Level 1 instead.
What I'm doing:
- I select a group of components, including plumbing fixtures, casework, and furniture.
- I copy them.
- I attempt to paste them into another level. I've tried the following paste options:
Aligned to Selected Levels
Aligned to Current View
Aligned to Picked Level
I've tried moving them in elevation using the Move command, but they only move laterally. I've selected them and changed their level to Level 2 in Properties, but they stay on Level 1 (and retain Level 2 in Properties).
In this case, I am pasting components between two files, and the beds and couches are showing up on Level 1. However, in the past, I've tried copying and pasting plumbing fixtures within the same file, and have seen fixtures that were supposed to end up on Level 1 floating around on Level 2, and vice versa.
Has anyone ever had this problem before? Do you know how to fix it?
Thanks!
