Thread: Toposurface wall intersect
    2011-05
    10
    Question Toposurface wall intersect
    Is there a way to show a line on an elevation view where the toposrface and say a site wall or an exterior building wall intersect?
    2001-03
    St. Louis
    75
    Default Re: Toposurface wall intersect
    the only thing i know is to put a pad in that matches the footprint of the wall, to cut a hole in the toposurface, to generate the edge line
  1. 2013: Footings that Intersect
    By clintonc in forum Revit Structure - General
    Last Post: 2013-03-28, 05:23 PM
  2. curve intersect result
    By sfaust in forum Revit - API
    Last Post: 2009-04-28, 03:19 PM
  3. No sideslope intersect found
    By benavlr in forum AutoCAD Civil 3D - General
    Last Post: 2009-01-16, 06:15 PM
  4. Roof problem : trss roof does not intersect exterior wall correctly
    By tim.101799 in forum Revit Architecture - General
    Last Post: 2008-01-29, 05:37 PM
  5. Intersect Geometry
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2006-11-28, 04:47 PM
