Does anyone know how to tag a conduit Top Elevation without it being relative to the conduit's schedule level? (For example: with Level 1 at 100', instead of 9' above the level I want to show the elevation as 109'.)
I couldn't find anywhere to specify Elevation Origin (as with Spot Elevations). I figured, it's not elegant, but I could just use a formula to add the 100' but I haven't been able to make that work either:
- If I try to refer to Top Elevation in a custom parameter in the tag family, I get this error: The following is not a valid family parameter: Top Elevation
- If I try to calculate the value in a shared parameter assigned to conduits, when I try to refer to Top Elevation I get this error: Formulas cannot refer to other parameters
Any suggestions?
Joel
