I swear I haven't noticed this problem before, but a facade I linked into a project isn't casting shadows in elevation view.
To be clear, with no view template or overrides everything looks right, but I have a view template that I use to just show cast shadows- it basically is set up to override all lines to white and to show shadow intensity at 100%. Linked files are set to be displayed by host view, too. With this view template applied, no shadows are being cast from the objects in the linked file.
I know there's probably a hundred things that could be at issue, I just wonder if you have any suggestions.
Thanks!
Sincerely,
James
