Results 1 to 10 of 19
Thread: Void visibility as a parameter?
    2010-08
    121
    Default Void visibility as a parameter?
    In a complex parametric family, I'd like to have a parameter to control whether a void is "visible" and cuts an object, or is "invisible" and doesn't cut. Normal objects have the ability to have their visibility turned on and off as a type or instance parameter, but it doesn't appear that voids do.
    I've seen some people establish parameters to move voids out of the way to effectively turn them off, but this seems like a brutish way of solving the problem.
    James
    2004-06
    Memphis TN area
    7,048
    Default Re: Void visibility as a parameter?
    I would do it like in the attached family. I used a "Not Cut" yes/no parameter, a Cut Depth "input" parameter (doesn't directly control the model), and another parameter called "d" which actually controls the void cut depth based on an If statement, referencing the first 2 parameters.
    2010-08
    121
    Quote Originally Posted by patricks View Post
    i just looked at your file and I'm not sure what the "Not Cut" parameter is attached to. I see it works, but I'm not sure how...
    Thanks!
    2015-12
    Vancouver, BC Canada
    3,753
    Quote Originally Posted by jameswest77 View Post
    It might seem brutish but that's the only way to do it. Think of it this way, you can't hide something that is nothing
    The Not Cut parameter in Patricks example actually defines the depth of the void (parameter d) so it either cuts or doesn't cut the host.
    2010-08
    121
    ah, i see, you're controlling the void visibility by adjusting it's dimensions. Neat trick, similar to moving it out of the way, but still a more complicated solution that just turning the void on or off.
    If this can't be done, I wonder why such functionality doesn't exist?
    And yes, I can imagine turning off a void, because it's a real object, regardless of whether it's visible or not. I can select it, it's a real thing.
    2010-04
    Gamehendge
    281
    I have done this by creating a plug extrusion for my "Not Visible" Condition. the plug can go on an on/off parameter no problem. I made a series of SubZ fridges with a window/solid door this way.
    2004-06
    Memphis TN area
    7,048
    Yes the Not Cut check box really just gives the user a quick way to change the void to cutting or not cutting the object, instead of having to change the cut depth to 0 manually.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    The other way to do this is to place a dimension to the void, that is something like void location. and then a formula that says if void = x then offset = x Basically move the void in and out of the object you are cutting.
    Scott D. Brown, AIA
    BECK
    100 Club jpolding's Avatar
    2005-06
    Southwestern Ontario
    198
    Thank you Patricks. Although I would like a visibility parameter for voids your solution worked like a charm.
    2010-06
    Omaha, Nebraska
    32
    In 2012 there is an option to select the extrusion boundary whilst editing the extrusion and selecting visibility along with parameters. However, it does not work the way I want, or it is over my head.
  1. Void Visibility Parameter in Family
    Last Post: 2015-09-09, 05:23 AM
  2. Void visibility in this specific family
    By let4mi in forum Revit Architecture - Families
    Last Post: 2011-11-30, 04:53 PM
  3. Turn Void Visibility On and Off
    By Scott Hopkins in forum Revit Architecture - Wish List
    Last Post: 2005-03-08, 12:17 AM
  4. Void affecting family visibility
    By woethesinner in forum Revit Architecture - Families
    Last Post: 2004-09-27, 09:01 PM
  5. Void and Topo Visibility
    By funkman in forum Revit Architecture - General
    Last Post: 2004-04-07, 10:56 PM
