Thread: "Reference Other View" Sections
    2002-09
    Madison, WI
    5,687
    Default "Reference Other View" Sections
    So I have a section that I created using the view/section tool. Now that detail is changing and moving to a different location. I've also referenced that view using the view/section/reference other view tool. So somewhere in my model I have a section cut that is referencing a detail that changed.
    Question
    I know you can use the "Find Referring View" tool to find the original section. Is there a way to find the section cut that was "Referencing Other View"? Other than searching visually?
    Thank in advance.
    2008-11
    Australia
    754
    Default Re: "Reference Other View" Sections
    put that view back onto a sheet temporarily, it will tell you which sheet it references...
  1. Improve the way "reference other view" view selection works
    By houston.cad in forum Revit Platform - Wish List
    Last Post: 2014-12-19, 06:22 PM
  2. I wish Revit could "Reference Other View" from linked files
    By sfong in forum Revit Architecture - Wish List
    Last Post: 2011-10-17, 03:14 PM
  3. "Show in current view only" option when adding sections, elevations or callouts
    Last Post: 2009-02-02, 08:02 PM
  4. "Reference other view" note/tag
    Last Post: 2009-01-31, 04:00 PM
  5. "Reference Other View" with section head
    By spooner24 in forum Revit Architecture - General
    Last Post: 2008-02-14, 06:20 PM
