Results 1 to 7 of 7
Thread: How to open a drawing from Windows Application?
    2008-04
    Las Vegas, NV
    19
    Default How to open a drawing from Windows Application?
    How can I get my app to open AutoCAD and then open the file that i have selected?
    Imports System
    Imports System.IO
    Public Class Form1
    Dim PathAcad As String = "C:\Program Files\AutoCAD Map 3D 2010\acad.exe"
    Dim DwgFile As String
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
    End Sub
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
    OpenFileDialog1.Filter = "Drawing File(*.dwg)|*.dwg"
    OpenFileDialog1.FileName = ""
    OpenFileDialog1.ShowDialog()
    DwgFile = OpenFileDialog1.FileName
    If IO.File.Exists(PathAcad) = True Then
    Dim p As New Diagnostics.Process
    p.StartInfo.FileName = PathAcad
    p.Start()
    End If
    End Sub
    Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
    Me.Close()
    End Sub
    End Class
    Thanks for any help!
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,227
    Default Re: How to open a drawing from Windows Application?
    Welcome on board
    Try attached code, it's very basic though -
    this will open a drawing by name and draw the circle
    in the model space, then it will save a drawing and nothing else
    Hope this will to get you started
    "The whole problem with the world is that fools and fanatics are always
    so certain of themselves, and wiser people so full of doubts."
    Bertrand Russell
    2008-04
    Las Vegas, NV
    19
    Smile Re: How to open a drawing from Windows Application?
    Thanks
    Corn
    2005-05
    Pietari, Venäjä
    1,227
    You're welcome
    But what is your goal?
    Cheers
    Bertrand Russell
    2008-04
    Las Vegas, NV
    19
    The Goal is to open a drawing or drawings and import a block or text and close drawing(s) and make read only.
    So when the next person open the drawing they will know not to make any changes.
    Thanks again.
    Moderator BlackBox's Avatar
    2009-11
    2,493
    Just curious, but isn't there a way (from a Windows app) to send the "Target" string from an AutoCAD application icon via Shell, using some startup switches?
    For example:
    "drive:pathname\acad.exe" ["drawing name"] [/switch "name"]
    More on Startup Switches.
    "Potential has a shelf life." - Margaret Atwood
    2005-05
    Pietari, Venäjä
    1,227
    Umm .. a lot of work, as well as it is needs after
    to set file attribute to read-only using FileInfo namespace
    Can you be more specfic?
    What is the block (from other drawing, attributed or not) &etc
    better yet step-by-step for my dim brain
    Ok, then I will try but I don't guarantee
    Attached is a quick exe, this will insert source drawing as block
    into the target drawing and make it read-only after
    Bertrand Russell
  1. Windows form based stand alone application
    By pasxos867044 in forum VBA/COM Interop
    Last Post: 2012-09-21, 04:20 AM
  2. Replies: 8
    Last Post: 2007-08-06, 02:58 PM
  3. Replies: 5
    Last Post: 2007-06-19, 01:53 PM
  4. Drawing Walk - a drawing browser CUI application
    By zoomharis in forum AutoCAD Customization
    Last Post: 2007-03-20, 10:45 AM
  5. Replies: 8
    Last Post: 2006-05-01, 06:39 PM
