Jrobker
The sides of your tapered wall aren't parallel. Once you initiate the dimension tool it sees the angle of the initial side picked and then takes that angle. When you go to the other side of the wall the Revit dimension doesn't even see that as a plane, so you can't pick it.
If you can dimension the one side (750) but not the other Revit must see the intersection as a point, rather than the face or you have a small portion of that wall that is parallel.
See if you can tab over the intersections while in dimension and get a point rather than a face.
Bottom line is if they're not parallel than you won't be able to dim.
