Thread: Autocad 2008 crashes on dwg 2007 open
    2011-06
    Montreal, QC, CA
    27
    Default Autocad 2008 crashes on dwg 2007 open
    New member at AUGI and at forums in general so please excuse if this already is a thread or if it's not in the right place.
    One of the users at my office cannot open dwgs with Mechanical 2008 without crashing autocad and I can't figure out why. The file was created with ACAD Mech 2011, saved in 2007 format and all the rest of us can open it. He can open all other files saved in the same process.
    Thanks for any insight
    Phil
    2011-06
    Montreal, QC, CA
    27
    Default Re: Autocad 2008 crashes on dwg 2007 open
    Anyone?
    Thanks!
    2006-04
    (0,0,+|Z|)
    1,125
    Do you use the later version of AutoCAD (v2010 or the later) in your office?
    If so, open that drawing by using the latest version.
    Enter "xref" and check if there is any external drawing attached.
    Bind the "xrefs" if you find any.
    The reason for this is the "saveas" does not save any "xrefs" to the other version format.
    The other things to check are that you need to ensure using Mech version of AutoCAD when open that drawing.
    You may have difficulty when open the drawing by using vanilla version as it may contain entities created by Mech version.
    2011-06
    Montreal, QC, CA
    27
    We use 2011 Mech standalones in the office part of the building - in the shop part of the building, they use older 2008 mech standalone licenses. We do have xrefs and we tried saving all ref'd documents in 2007 as well, but I'll try to bind the drawings and see what happens.
    Seems to work when we bind the xrefs, but this is counterproductive as we need to update our drawings regularly. The other option we are working with now is to: Partial read-only open the files; and ensure that xrefs are unloaded at open while maintaining all active layers. This works but only one person can access the file at once.
    Thanks for the input
  1. autocad 2008 crashes
    By travis.181692 in forum AutoCAD General
    Last Post: 2008-09-24, 01:23 PM
  2. AutoCAD 2007 and 2008 unable to open a DWG file saved in 2004 format
    By Neo_Richard_Blake in forum AutoCAD General
    Last Post: 2007-07-09, 08:50 PM
  3. Map 3D 2007 crashes when trying to open Layer Manager
    By jiles in forum AutoCAD Map 3D - General
    Last Post: 2007-07-06, 08:09 PM
  4. 2007 Crashes with multiple drawings open
    By clarkrj in forum AutoCAD General
    Last Post: 2006-10-18, 05:32 PM
  5. AutoCAD 2005 crashes when trying to open a sheet set linked drawing
    By RICHARD_JONES in forum AutoCAD Sheet Set Manager
    Last Post: 2006-09-01, 07:53 AM
