greenwaldc
Can you post a screenshot of your clash detective selection tab?
I've found that I need to create search sets first, then create a clash test which clashes one search set vs. another search set. By doing this, I have been able to export an .xml file, and import it to a new file. The import will copy over the search sets as well as the clash tests.
One of my .XML files is about 200kb, and contains 3 dozen clash tests.
FWIW, I was also able to use the .xml file created in NWM 2011 when I upgraded to 2012.
