Thread: Auto Cad floor plans to Revit
    2004-11
    20
    Question Auto Cad floor plans to Revit
    I could use some direction on importing specific floor plans or view ports from auto cad into Revit for recreating in Revit..I have no problem importing the whole file, but getting a specific view port in auto cad to a specific view in Revit has been difficult.
    100 Club Scott_Bloss's Avatar
    2003-11
    Syracuse - New York
    186
    Smile Re: Auto Cad floor plans to Revit
    I would go to model space in AutoCAD to the view or plan that you would like and copy the information to the clip board. you can also make a block in Autocad of the information you want and import the block in to a Revit drafting view. or go in to Revit set up a drafting view to the same scale and paste the information into the drafting view from the clip board then plan the information on a sheet. Hope this helps.
    I could stop if I wanted to Paul Monsef's Avatar
    2003-09
    Everett, WA
    351
    Default Re: Auto Cad floor plans to Revit
    Quote Originally Posted by gallienhanson
    I could use some direction on importing specific floor plans or view ports from auto cad into Revit for recreating in Revit...
    Sounds like you have a messy CAD file with a zillion layers and a million viewports to look at your zillion layers...
    What you could try is to WBLOCK out each "view" you wanted to import into Revit (do this through the Paperspace viewport). Then, import the Wblock DWG into the appropriate Revit view and recreate away!!
    I could stop if I wanted to Simon.Whitbread's Avatar
    2003-06
    London, UK
    352
    Quote Originally Posted by Scott_Bloss
    I would ... copy the information to the clip board. ... or go in to Revit set up a drafting view to the same scale and paste the information into the drafting view from the clip board .
    Not quite correct, Wblock the drawing entities to a seperate file, then import THAT file into your drafting view
  1. AB218-1: Autodesk® Revit® for Conceptual Floor Plans
    By Autodesk University in forum Architecture and Building Design
    Last Post: 2014-11-30, 01:12 PM
  2. Revit vs. Auto Cad for residential house plans
    By raymondjdawson925863 in forum Revit Architecture - General
    Last Post: 2012-07-16, 05:32 PM
  3. Conceptual Design and Floor Plans - Revit 2010
    By Brian Myers in forum Revit Architecture - General
    Last Post: 2009-11-07, 04:29 PM
  4. Exporting Floor Plans from Revit (Text)
    By anthony.foster-davis in forum NavisWorks - General
    Last Post: 2009-07-14, 11:26 PM
  5. Exporting Revit Floor Plans to ADT
    By mmcclure in forum Revit Architecture - General
    Last Post: 2008-02-22, 06:31 PM
