Is it possible to link the distance of an array action to the distance of a scale action? Example: The attached batt insulation block. I want to be able to insert the block and grab the scale grip and scale the block to fit the cavity it is being used for. Then, I can grab the grip for the array and make it fill the length of the cavity. This works well if I do it in the reverse order, but not in the order I'd prefer. Also, if I do it in the order that does work and then I go back and mess with it again (say the cavity got larger or shorter), then it seems to get all out of wack.
Any suggestions will be taken to heart and bastardized to my hearts content.
Thanks in advance,
Beardking
