Thread: Project Templates
    2011-07
    Default Project Templates
    I am a new GBS user and am having a problem using Project Templates. I have created a new template to approximate ASHRAE 90.1-2001 standards, saved it and loaded it into my project. When I run the project, the new template appears in the Energy Results tab under "Project Template Applied", but none of the Building Details and Assumptions update and all the energy data remains the same as prior to the application of the new template.
    I am using a student license for GBS. Could this be the issue? Any other thoughts or suggestions would be much appreciated.
    Thanks
    4
    Default Re: Project Templates
    I have the same problem with GBS and Project Templates and I'm using the full version on Subscription. I think that the templates just don't work at all that I can see. I have been just doing one run and then using the Design Alternatives to put in the specific assumptions I want to use. A pain indeed.
  1. Replies: 0
    Last Post: 2014-11-30, 01:16 PM
  2. 2014: Setting Up Project Templates & View Templates???
    By sbrennan in forum Revit MEP - General
    Last Post: 2013-08-29, 09:17 PM
  3. Templates from an existing project??
    By the_gibson in forum Revit Architecture - General
    Last Post: 2009-07-20, 10:27 AM
  4. Loadinbg Project Templates
    By oxidation in forum Revit - Platform
    Last Post: 2008-04-25, 10:14 PM
  5. Project Templates
    By interceptor59 in forum Revit - Student Support
    Last Post: 2006-01-19, 04:42 PM
