I've run across what seems to be a really annoying bug with LDD, and hope someone has a workaround.
I've been labeling a plat, using the line labeling commands in LDD. I want to create wipeouts behind these labels. However, this doesn't seem to work.
The problem is any line that was labeled with a label style that splits the label into two pieces. For example, "bearing, distance above". When I attempt to apply a wipeout to this text label, it works fine on the distance part, but completely erases the bearing part.
Selecting text objects created with the label command and exploding them does the same thing - the distance part stays there as expected, but the bearing part gets deleted.
Anyone know any workaround, besides "don't use LDD label commands" or "don't use wipeouts"?
(Note: running Autocad/LDD 2004)
