Results 1 to 6 of 6
Thread: Line & Curve table settings
    2011-07
    3
    Default Line & Curve table settings
    I am trying to figure out how to get line and curve tables looking better and taking up less space. In the table style settings I can change everything but the data cell row height. Does anyone know how to reduce/change the row height? It seems to me this is a pretty basic setting that one should be able to change. I really don't want my cell height to be 3x the text height, period. Give me the choice please.
    Using Civil 3D 2011, Windows 7
    2011-07
    3
    Default Re: Line & Curve table settings
    So I got an answer. You CAN'T change the row height in line and curve tables. What they set is what you get.
    Can you say stupid? I can.
    Carl Simpson
    Civil Designer
    Denver, CO
    2010-11
    3
    I can too it is called "AutoCAD". I'm so sick of having to deal with half working garbage from this company. People wonder why no one wants to switch to Civil3d... because you can't get waht you want from this steaming turd!
    2010-04
    53
    agree. other examples:
    1. a draped image on a surface is rotated by 90 degrees unless hardware acceleration is off.
    2. can neither import nor export to ESRI GIS formats
    3. cannot build a legend of or save a raster surface analysis style
    4. cannot autoelevate a multiview block to a surface
    5. cannot create or edit ones own palettes of colors for surface analysis
    6. cannot use attributes in multiview blocks (no tree plans!)
    7. cannot do viewshed analysis on a surface raster
    8. no option to project a SECTIONPLANE of a block into a profile/section instead of a plan
    9. cannot data shortcut an intersection object
    10. parcel ROW is not dynamic to alignments
    11. cannot use true vertical planes in a corridor
    12. corridor cannot solve self-intersections of daylight subassembly
    13. the retaining walls haven't any links across the face (no visualizations)
    14. cannot remove the index column of a table
    2001-10
    Arizona
    2,337
    YES you can
    Yes you can
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2010-04
    53
    in theory yes you can import and export in practice it is error after error. cannot open .gdb files cannot open .mdb files. DEM exports from civil3D are clipped in GIS ect. ect. only LandXML works for TIN sufaces
    yes you can create the color paletters IF you know XML and, and know the RGB values of each color, and are willing to search for the ARM file edit and update and hope you don't mess up your install in the process. compare to ESRI where you just pick colors off a palette...
  1. Curve Calculater Settings
    By bieber in forum AutoCAD General
    Last Post: 2008-04-23, 12:52 PM
  2. Curve calculater settings
    By bieber in forum AutoCAD Civil 3D - General
    Last Post: 2008-04-23, 12:15 PM
  3. Zoom to Curve or Line from Table
    By .T. in forum AutoCAD Land Desktop - Wish List (Closed)
    Last Post: 2006-02-09, 06:22 PM
  4. Line and Curve Table Problems
    By raylitalo in forum Land Desktop - General
    Last Post: 2004-10-05, 01:55 PM
