Thread: Vertical Conduit and Cable Tray Justification
    2015-12
    17
    Default Vertical Conduit and Cable Tray Justification
    Does anyone else have a problem with vertical justification? If I justify 2" high cable tray for example to a 9' offset it shows 8' 11" for the bottom and 9' 1" for the top. This is the same no matter if I choose top, center or bottom.
    2007-01
    Suwanee, just north of Atlanta
    160
    Default Re: Vertical Conduit and Cable Tray Justification
    I just tried what you describe and it works fine for me. My workflow is: select the Cable Tray command, set the tray height to 2", select the Justification button and change it to bottom, and then place. Once placed, I selected the tray, checked the properties and it is correct. I was in floor plan view. I am in RMEP2012 with the latest service patch. In the Justification dialog, you should not have any additional offset value.
    Last edited by dennis howell; 2011-07-13 at 01:11 PM. Reason: another thought to add
    2015-12
    17
    OK. Got it figured out. After setting the values needed if you look in the properties it gives you incorrect information UNTIL the conduit or tray is modeled. After it is modeled it reports the correct info. Thanks for the reply though.
  1. Conduit - Cable Tray Disappears
    By pasteele in forum Revit MEP - General
    Last Post: 2012-08-14, 04:31 PM
  2. [2009] Conduit and Cable Tray (GRANTED)
    By sschwartz85916 in forum Revit MEP - Wish List
    Last Post: 2010-04-26, 04:09 PM
  3. RMEP Steering (conduit/cable tray)
    By darin.marsden in forum Revit MEP - General
    Last Post: 2009-04-03, 01:12 PM
  4. RMEP Steering (conduit/cable tray)
    By darin.marsden in forum AMEP General
    Last Post: 2009-04-02, 05:22 PM
  5. Wiring Methods (Conduit and Cable Tray)
    By jason.martin in forum Revit MEP - General
    Last Post: 2009-03-30, 08:34 PM
