Has anyone found a good way to show a Chain-Link fence? As or right now I'm using a vertical surface from Civil3d and applying a transparent wire mesh across it. This works ok, but in order to get the material to look correct when the fence turns I have to have each straight segment a different surface.
I wanted to use the railing objects in Revit, but with this I'm not able to place the objects in Revit at the correct elevations to go along with my civil3d surface, I'm stuck using my above method.
