Thread: double slding door
    2005-07
    Melbourne, Australia
    92
    Default double slding door
    Help required with double sliding exterior glass doors with fixed glass panel either side. Doors to open in opposite directions
    Forum Manager, Administrator Ed Jobe's Avatar
    Turlock, CA
    4,791
    Default Re: double slding door
    When requesting help, you need to say more than "help required". What exactly do you need?
    C:> ED WORKING....
    I could stop if I wanted to neje's Avatar
    2002-12
    235
    Hi Westcad, I've attached my window catalogue styled on Stegbar with some exceptions.
    There is a DWA that I use for FSSF sliding door. Not sure if it works as well as it should because I'm unsure how to 'connect' the inserts to the style so they'll hold. The insert is just a regular sliding door with the outer frame turned off (width 0).
    feel free to email me direct if you have any questions about what I've done there. It works really well ( the whole cat) for fast insert of different windows and they have brick sizes built in.
    cheers
    Nathan ntellery aatt gmail dottt com
  1. Dynamic Double Door Set, scale the two door leafs uniformly
    By b.boyes in forum Dynamic Blocks - Technical
    Last Post: 2012-08-08, 03:58 PM
  2. Double Egress Door ?????
    By Kal_digital in forum AutoCAD General
    Last Post: 2008-11-18, 04:58 PM
  3. Replies: 1
    Last Post: 2008-09-17, 04:23 PM
  4. Double door
    By billynutts in forum ACA General
    Last Post: 2008-02-13, 09:36 PM
  5. Need single-door equivalent of Revit's "Store Front Double Door"
    By Ralph.143107 in forum Revit Architecture - Families
    Last Post: 2007-10-27, 11:49 PM
