Thread: Corridor Style
    2007-03
    Huntingdon, TN
    96
    Default Corridor Style
    How do I change the color of the lines that run along the center line of the road, curbs, etc.?
    Where would if find a white paper or similiar that really explains how to change the looks of a corridor? From what I can tell a corridor is represented by a collection of styles. I am not sure which styles they are or where to find them.
    Anthony
    Civil 3D 2012
    2003-12
    Northern California
    561
    Default Re: Corridor Style
    Here's an Autodesk University 2009 class that may help:
    http://au.autodesk.com/?nd=class&session_id=5137
    The key here is Code Set Style, which uses Featureline, Marker, Link, and Shape Codes. All of these can be found under Settings/General/Multipurpose section of Toolspace.
    2007-03
    Huntingdon, TN
    96
    Thanks, I will watch it. I have been trying to make a point to watch a couple of those videos a week. I do a pretty good job but I doubt I will ever get through them.
    Anthony
    Civil 3D 2012
  1. Set Plot Style-Assign Style to Layer
    By jeff.richards in forum AutoCAD General
    Last Post: 2010-02-02, 04:54 PM
  2. I create a Corridor Surface but no Corridor Surface appears?
    By eraska in forum AutoCAD Civil 3D - Corridors
    Last Post: 2007-08-21, 09:50 PM
  3. Changing the style of your Corridor Feature Lines
    By melanie.santer in forum Civil 3D Tips & Tricks
    Last Post: 2006-10-27, 03:39 AM
  4. Replies: 1
    Last Post: 2005-02-17, 02:12 PM
