Results 1 to 9 of 9
Thread: cannot explode block
    23
    Default cannot explode block
    I have a block which I cannot explode. The block has authoring elements so I have opened it in the block editor but cannot find a parameter to allow exploding. Where can I change this setting?
    100 Club JeffClark's Avatar
    2002-07
    South Jersey
    121
    Default Re: cannot explode block
    Could it be that it has different X and Y scales? Or maybe it is on a different XY plane than the current one?
    2005-06
    in the upper right corner
    3,033
    Quote Originally Posted by LynNV View Post
    Can you go into the standard "Block Definition" editor and find the block, and check off "Allow Exploding"?
    Ted
    ____________________________________________________________________ ________________
    Windows 7 Professional
    AutoCAD 2017 - REVIT 2017 - Inventor Professional 2015 (when I can)
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    559
    You can explode it via vba.
    Sub ForceExplode()
    On Error Resume Next
    Dim retBlock As AcadBlockReference
    ThisDrawing.Utility.GetEntity retBlock, basePnt, vbCrLf & "Select Non-explodable Block to Explode"
    retBlock.Explode
    retBlock.Delete
    End Sub
    If the cause of being unexplodable is just unchecking the "Allow Exploding" option while creating the block, that's easy. But if the reason is varying x,y, and z-scale, its a different story. If the resulting object is valid, then it can be exploded. For example, a circle inside a block is non-uniformly scaled, when exploded will be an ellipse-valid. But a non-uniformly scaled sphere, when exploded will result to a null object and therefore will be deleted. So it depends on the type of objects inside your block.
    Shielbern Bolalin
    Architectural 3D Renderer
    “A clever person solves a problem. A wise person avoids it.”
    1879-1955
    2004-08
    Hartford, Michigan
    3,192
    with nothing selected, the explodeable property should be listed in the properties palette. Otherwise, a LISP routine could also prevent exploding of blocks.
    Christopher T. Cowgill, P.E.
    AEC Collection Civil 3D 2018
    Windows 10
    2009-06
    Toowoomba, QLD, Aus
    72
    If I can only apply that to MTEXT and Dimensions
    0,0,0 The Origin
    8,569
    Quote Originally Posted by matthew.221135 View Post
    Mtext and dimensions can be exploded - or were you going into further detail with this?
    John B
    2005-02
    Off the Grid
    559
    Quote Originally Posted by jaberwok View Post
    I think he wants to uncheck it to prevent exploding.
    Shielbern Bolalin
    1879-1955
    0,0,0 The Origin
    8,569
    Quote Originally Posted by arshiel88 View Post
    Doh!
    you're probably right.
    John B
  1. 2009: Block won't explode
    By Bill.Jensen in forum ACA General
    Last Post: 2014-03-08, 02:24 PM
  2. how to explode minserted block
    By mohsin_hafiz2002839758 in forum AutoCAD General
    Last Post: 2012-10-08, 11:50 AM
  3. Unable to Explode block
    By Jawwad Malik in forum AutoCAD General
    Last Post: 2010-05-28, 11:44 AM
  4. Explode(?) field after block insertion
    By dweber.134794 in forum AutoCAD Fields
    Last Post: 2008-01-21, 09:26 PM
  5. Explode block refernce
    By rcox898534 in forum AutoLISP
    Last Post: 2007-07-23, 05:31 PM
