mhartmann
i've built the clearances into my panel families. it's a cube (transparent cyan, with a dashed outline, so it looks like glass in 3D) the size of the front of the panel, with a depth parameter, default 3', but you can change it. there is also a cube the size of the top of the panel that goes up. i don't remember the formula, but got it to go up to 10'AFF, you can also change it's height, or stretch it in section, up to deck. you should make these on a sub-category that other disciplines can turn off. you can also interference check the clearances, since they're a physical entity, against ducts, pipes, etc.
Mike
