Hello,
I used the default out of the box cable tray in Rvit MEP 2012, and then proceeded to tag the tray using the cable tray size tag. The tag has the diameter symbol shown at the end, which does not seem right to me, is this a fluke? or does any one has a reasonable explanation for this?
For example, a tag for a 24" x 4" cable tray will be shown as: 24" x 4" ∅.
The work around for this was to make the tag use a different parameter, and manually type in the size; I'd like to use the size parameter though, but not sure how to fix the bug given that cable tray is a system family.
