Results 1 to 10 of 11
Thread: Revolve/Extrude along a curved path?
    2011-07
    16
    Default Revolve/Extrude along a curved path?
    I'm still relatively new to this new Ribbon UI for Revit and find myself struggling with what should be simple geometry. I'm trying to extrude a circle along a curved path to simulate the look of rope for our Railing System. I seem to remember there being some useful tools in Revit 2008 such as Revolve/Extrude and was wondering if those tools actually exist in this new platform. Knowing Autodesk however, they probably purged most of those useful massing tools and snickered about how crazy it makes everyone. Lol
    2004-06
    Memphis TN area
    7,048
    Default Re: Revolve/Extrude along a curved path?
    What you're looking for is a Sweep, which lets you draw or pick a path and then sweep a shape along that path.
    2004-05
    St. Louis, Missouri
    3,135
    Wink Re: Revolve/Extrude along a curved path?
    Patricks is correct--use a sweep.
    And to your comment on Massing--quite the contrary.
    Autodesk has vastly improved the Conceptual Massing tools--take a look here:
    http://buildz.blogspot.com/
    cheers
    2003-04
    Chino, CA
    4,756
    Quote Originally Posted by cliff collins View Post
    cheers
    And if it is part of a Railing, why not just use the railing tool rather than trying to model sweeps? The railing tool will build the sweeps for you along a straight or curved path. Also, when you say "rope" are you trying to actually model a "spiraled" look, or just the circular extrusion to represent the rope?
    2011-07
    16
    No. I don't need to worry about that level of detail. Just a circular extrusion.
    OP likely wants "drooping" ropes between posts, not possible with railing tool I don't think. If you look on Revit City you can find some families I uploaded some years ago called "stanchion poles" and the ropes that go between them, for creating queue lines.
    Awesome! I'll definitely check them out. TY.
    That would be the one I'm looking for! Now I just need to locate said tool. Lol.
    Thank you everyone for your help!
    2003-04
    Chino, CA
    4,756
    Quote Originally Posted by jeff112408 View Post
    Ah now i get it! Curving path vertically...not that you need this level of complexity, but what came to mind now was to use Project Nucleus and apply gravity to a form to make it "droop" properly as a catenarycurve, as a rope should!
    2004-06
    Memphis TN area
    7,048
    Quote Originally Posted by Scott Davis View Post
    ...Project Nucleus and apply gravity to a form to make it "droop" properly as a catenarycurve, as a rope should!
    I have never heard of this before now!!!
    I see it on the Labs website. Is it only available for Revit 2011?
    2004-06
    Memphis TN area
    7,048
    2015-08
    84
    Quote Originally Posted by patricks View Post
    It is entirely possible if you model the rope as part of the post. You'd need two different posts, one end post without a rope, and one post with a rope.
    2004-06
    Memphis TN area
    7,048
  1. 2011: extrude along 3d path
    By dennis.moyes in forum AutoCAD 3D (2007 and above)
    Last Post: 2015-04-24, 12:14 PM
  2. Pipe- extrude or revolve
    By fsl88 in forum Inventor - General
    Last Post: 2011-08-23, 10:21 PM
  3. extrude along a path
    By tomcarver in forum AutoCAD 3D (2006 or below)
    Last Post: 2008-02-01, 11:34 PM
  4. AutoCAD 2006 extrude along a path - Profile and path are tangential.
    By judekw in forum AutoCAD 3D (2006 or below)
    Last Post: 2007-05-24, 07:48 PM
  5. Extrude a profile along a curved path
    By dlampley.41310 in forum AutoCAD 3D (2006 or below)
    Last Post: 2006-08-07, 12:08 PM
