Thread: UK Based System Wall Family
    2003-11
    Sutton Surrey United Kingdom
    238
    Default UK Based System Wall Family
    Ralph Pullinger and I are looking at developing a UK Based System Wall Family Template, and we require your help. But in order to do so you will need a little background information and briefing on the kind of information we need to know, and our thoughts so far...
    Pop over to http://cadalot-revitlearningcurve.bl...milies-uk.html and have a look at the background and starting point for this thread....
    Q: What do you think of Ralphs proposed naming convention against that in GRBENU_Walls.rvt ?
    Q: To me light weight blockwork is Aircrete, What is normal weight blockwork?
    Q: Cavity or Air Gap?
    Q: What actual wall configurations are you specifying on real schemes from all those offered by the block and thermal insulation manufacturers?
    Post Re: UK Based System Wall Family
    Alan, Ralph,
    Re providing examples of current wall construction in the UK. Would it help respondees and yourselves if the examples were supplied in a standard format. I am thinking of an excel sheet with columns for the relevant parts of a wall construction, that contributors could populate and send back to you, and thus contain the info in a format readily useful to you.
    Brian Napper
    TPS
    2003-11
    238
    Default Re: UK Based System Wall Family
    Not quite as easy as you think inless you have outer face / Core / Inner face because you can a single leaf of masonry or a cavity construction of some description. The list in the GRBENU_Walls is a good starting point.
    I will have a play and come up with something that people can add too or select from but just letting us know what you are currently specifying would be really helpful
    Regards
    Alan
    2003-11
    238
    Brian
    See the Architecture Thread http://forums.augi.com/showthread.php?t=132040 for an excel spreadsheet. starter for 10 - I'm not saying that the Key being currently used in the spreadsheet is what we will finally end up with but it's catch 22 we need to know how many different wall configurations are actually being used to see what we need in the system and how it will look like in the end.
    Please add your wall configurations to this thread i.e. Here is a typical one from a recent scheme I worked on:-
    25 x 125 Thermowood Cladding
    42 x 42 Horizontal battens
    21 x 50 Vertical battens
    breather membrane
    100mm medium density block
    100mm cavity filled with mineral wool
    100mm lighweight block
    20mm Plaster
  1. UK Based System Wall Family
    By Alan aka cadalot in forum Revit Architecture - United Kingdom
    Last Post: 2011-11-23, 02:21 PM
  2. System parameters in a generic face-based family
    By RobertB in forum Revit MEP - Families
    Last Post: 2010-02-11, 10:16 PM
  3. How do you changing a wall based family into a face based one
    By speedfreak5150 in forum Revit Architecture - General
    Last Post: 2009-07-13, 05:21 AM
  4. Convert wall based family to generic family
    By BATx2 in forum Revit Architecture - Families
    Last Post: 2007-09-27, 06:03 AM
  5. wall based family 3d preset to placement side of wall
    By sbrown in forum Revit Architecture - Wish List
    Last Post: 2003-07-15, 08:57 PM
