Results 1 to 10 of 10
Thread: ObjectARX
    2006-05
    Pind
    63
    Default ObjectARX
    i want to install ObjectARX in AutoCAD 2010 and using visual studio 2010 please can u guide me how can i do this step by step.
    thanks
    Forum Manager, Administrator Ed Jobe's Avatar
    Turlock, CA
    4,791
    Default Re: ObjectARX
    Look at the Getting Started thread stickied to the top of this forum. Download and install the sdk. Then use the wizard to create a new project.
    C:> ED WORKING....
    2008-04
    St-Ferdinand, Québec
    124
    I took a look at the Getting Started thread sticked and I found nothing about ObjectARX_2011_Win_64_and_32Bit vs Microsoft Visual Basic 2010 Express...
    When I start the ArxWizards.msi a message appears:
    MVS 2008 must be present on the target machine...
    Is someone could help me ? Thanks in advance !
    2006-12
    1,525
    That depends what you are trying to do. If you are creating ARX applications, you will need Visual C++ 2008 (at least Professional, if I remember correctly). If you are creating managed .NET plug-ins you don't need to install the ARX Wizards.
    If you are going to fly by the seat of your pants, expect friction burns.
    Windows XP is now over 10 years old, in software terms it makes Joan Collins look like the new kid on the block. - Statler
    Everyone else being wrong is not the same thing as being right.
    2008-04
    124
    Im following the Autocad help:
    After a new project is created, you will need to reference the files that make up the AutoCAD .NET API. For information on referencing the files associated with the AutoCAD .NET API and installing the ObjectARX Wizard for AutoCAD 2011, see Components of the AutoCAD .NET API.
    http://docs.autodesk.com/ARCHDESK/20...8c7ca-47a5.htm
    In the Topic: To create a new project using an AutoCAD Managed template
    Im beginning to .NET vs Autocad...
    Thanks !
    Moderator BlackBox's Avatar
    2009-11
    2,499
    Quote Originally Posted by EDDemtec View Post
    To get you started, download and install (in this order):
    Visual Studio 2010 Express
    AutoCAD ObjectARX SDKs
    AutoCAD .NET Wizard
    Edit: Using this .NET Wizard adds a new "AutoCAD plug-in" template for Visual Studio 2010 Express (C#/VB) which automagically includes references the AcDb.dll, and AcDbMgd.dll files found in the ObjectARX SDK for your version of AutoCAD.
    "Potential has a shelf life." - Margaret Atwood
    2008-04
    124
    Hi Renderman !
    Now it seems to be work, as per my printscreens...
    After that, when a project is ready in VSE2010, what do you suggest to me ?
    I already developped with VB6, but as I said, Im really new with .NET/Autocad
    Thank you very much !
    2009-11
    2,499
    No worries; we all start somewhere.
    Starting with VB.NET given your familiarity with VBA is going to be the simplest transition for you, IMO. However, at some point you may need to learn C#, or even ObjectARX (C++ for AutoCAD).
    In any event, so we do not hijack this thread further, perhaps the AutoCAD .NET Developer's Guide would be a good place for you to start?
    Please post non-ObjectARX questions in a separate thread, with an appropriate name.
    ^^ Sorry, Ed.
    2008-04
    124
    Quote Originally Posted by RenderMan View Post
    ^^ Sorry, Ed.
    Ooopss, it's noted !
    Thanks again !
    2009-11
    2,499
    Happy to help!
  1. Where is ObjectArx from Autodesk?
    By Dan.Anderson in forum AutoCAD Customization
    Last Post: 2011-12-07, 09:25 PM
  2. about ObjectARX
    By mdsalman2003 in forum ARX
    Last Post: 2010-06-11, 12:22 PM
  3. ObjectARX Enabler
    By h.jobe in forum AutoCAD General
    Last Post: 2010-03-18, 09:37 PM
  4. Autolisp, ObjectArx, Vba
    By alanferreira.l in forum Português - Customização / Programação
    Last Post: 2010-02-15, 09:23 AM
  5. ObjectARX class!!!
    By chris.kulhanek in forum ATP Course Wishlist
    Last Post: 2006-07-05, 09:35 PM
