Thread: Globally remove mtext formatting
    2010-04
    39
    Default Globally remove mtext formatting
    I have drawings that have had the text style changed to a different font. Issue is that some of the mtext has character formatting that is the old font. Is there a way that I can change/remove the formatting globally? I do not want to remove the formatting individually.
    Thanks in advance.
    Cairo - no, not Illinois
    5,069
    Default Re: Globally remove mtext formatting
    2010-04
    39
    Thanks, works great.
    2010-11
    3
    I used the stripmtext lisp as well. Very useful. Thanks to Steve Doman and Joe Burke who came up with this. I was looking at a lot of work to remove formatting from 100+ mleaders.
    Matt
    2010-03
    4
    Has anyone had the chance to update this to any newer Auotcad Versions. I am running 2017 and I can't this to strip anything. Unless theres a system setting that I have set wrong.
    Thank you.
    Paul
  1. Globally Converting Dtext to Mtext
    By rmaillet in forum AutoCAD Annotation
    Last Post: 2008-12-11, 12:54 AM
  2. Remove formatting from MText objects
    By kwong in forum AutoCAD General
    Last Post: 2007-02-12, 03:53 AM
  3. Globally Edit MText Objects
    By ldibenedetto in forum AutoCAD General
    Last Post: 2006-06-09, 12:11 PM
  4. Remove Font formatting in MText
    By tedg in forum AutoCAD General
    Last Post: 2006-03-23, 04:26 AM
  5. Any way to globally select Mtext and explode it?
    By drafterjohn in forum AutoLISP
    Last Post: 2005-03-14, 06:34 PM
