Results 1 to 10 of 19
Thread: Aligning Surface Patterns
    2010-07
    New Orleans
    39
    Default Aligning Surface Patterns
    I am not able to align/move/rotate the surface pattern for any model component the way it is possible for walls, floors, etc. I am specifically dealing with Architectual Column family where I need to adjust the suface pattern to mach the walls, and a few Generic Model families that represent brick moldings. I have confirmed the pattern being used in all these cases is a Model pattern, not a Drafting pattern.
    In all of the above cases, when I Tab-select the surface pattern and align/move/rotate, instead of just the patterning moving, the entire component moves.
    What am I missing here? Has anybody else ran into similar issue?
    Thanks.
    2011-01
    151
    Default Re: Aligning Surface Patterns
    Yes, I've run into this...the whole family wants to move. What puzzles me about your image is that the two pieces should line up vertically at least. When I've had situations like this, and I just tested it to confirm it, the patterns line up vertically. Makes me wonder if there is an offset or constraint issue with either your wall or your family that is making them not line up vertically.
    I could stop if I wanted to Merlin's Avatar
    2004-05
    Brisbane, Australia
    404
    Have you tried to re-align the pattern when editing the family itself?
    2010-07
    New Orleans
    39
    Quote Originally Posted by Merlin View Post
    The family has a material parameter. So the surface pattern shows up only in the project when you select a specific material for the family, in this case, brick.
    Certifiable AUGI Addict cliff collins's Avatar
    2004-05
    St. Louis, Missouri
    3,135
    Wink Re: Aligning Surface Patterns
    I suspect it is something with the Family--the extrusions or sweeps or whatever it was built from.
    Would it be possible to use Host Walls instead of a wall-based family? It would be easier to align the pattern
    if everything were Host Walls.
    ( I can't tell from the image how complex the form is for the Family ).
    cheers
    Cliff B. Collins, Registered Architect / BIM Specialist
    St. Louis, MO
    2010-07
    New Orleans
    39
    Quote Originally Posted by cliff collins View Post
    cheers
    My question is very broad, the above specific family is only to illustrate an example. As mentioned in my original questions - I have ran into this with everything other than walls/floor/ceilings. Even if I figure out a workaround for the above example, the bigger questions of how to align suface patterns in custom families still needs to be answered.
    2004-05
    St. Louis, Missouri
    3,135
    OK-- understood. Thought you were only solving an individual problem.
    Try applying the SAME EXACT material that is in the Project in the Family, if you haven't already done so.
    Then reload into the Project and try aligning the Model Pattern.
    Any luck?
    St. Louis, MO
    2010-07
    New Orleans
    39
    Any luck?
    Aligning pattern within the family does work. The question still is - how do you do it in the project? Becuase most times, you need the surrounding context for alignment.
    2004-05
    St. Louis, Missouri
    3,135
    Let's clarify:
    1. Did you used the same exact material ( brick ) in both the Family and the Project?
    2. If so--let's assume yes--then load the family into the Project, then try to align the pattern. Does it work?
    Just checking/troubleshooting. I tried it on a quick example and it works for me.
    cheers
    St. Louis, MO
    2010-07
    New Orleans
    39
    Let's clarify:
    cheers
    Doesn't work for me. If it does work for you, maybe I am doing something wrong.
    One other example - Please see the attached image. The architectural column family is circular. In this case even aligning the pattern within the family doesn't work.
  1. 2013: Aligning surface patterns
    By gsteffen642486 in forum Revit Architecture - General
    Last Post: 2013-08-06, 01:37 PM
  2. Aligning Model Patterns
    By jcoe in forum Revit Architecture - General
    Last Post: 2006-08-18, 03:29 PM
  3. aligning floor patterns
    By jeff.95551 in forum Revit Architecture - General
    Last Post: 2006-05-04, 12:32 AM
  4. Aligning Render Patterns
    By DanielleAnderson in forum Revit - Rendering
    Last Post: 2005-04-01, 12:35 AM
  5. Aligning Patterns on Massing?
    By tgrinstead in forum Revit Architecture - General
    Last Post: 2005-02-09, 09:51 PM
